Bit of bad luck, was retuning from a days 4wd'ing when my clutch shat itself
I had a look and sure enough its the clutch slave cylinder, leaking from the main seal.
Now.... my truck is out on some old dusty road in the middle of nowhere overnight or until i can get it home.
The clutch fluid must be completely drained because i cant get it into gear at all.
Vehicle: 1989 Hilux Surf SSR 2.4L Turbo Diesel
1) where the hell do you fill the clutch fluid up from?
2) if i fill it up do you think it could work just to get it home?
3) how hard is it to replace the clutch slave cylinder? (any special parts etc...)
Thanks guys! all feedback very welcome!
-Chris
-Chris
