Hi all, am looking for advice on the above symptom.
have been having problems with engine running cool and extra juicy since start of cold spell. have found problem with turbo boost pipe (thanks Bushwacker) sorted problem and reset ecu (eventually) as could not persuade it to give me the code owing to current problem with the check light not coming up at ignition live?!! this is an intermittant problem as mentioned above and normally only happens when engine has run that day, am presently trying to check for any fault codes with the engine cold but am unable to get check light up at all.
am now in a state of complete bafflement as the beast starts first turn from cold, and seems to run fine (if juicier than in the past) even if the check light does not come up...
Any and all ideas gratefully recieved,
Regards, Paul
Regards, Paul
