Rear coil springs
  • Rear coil springs
    Hi all ,
    Got a 2.4 with saggy ares syndrome .
    What coil springs do you guys recommend
    Milners standard £47 or roughtrax 2'' lift £79
    Daz
    It depends what you want to do.
    Standard springs = back to standard
    RT +2 = +2", you need new +2 dampers and you'll get a bit more articulation.
    LC80 Springs = +2", and you need new +2 dampers, but much cheapness and less articulation (too stiff).
      I just installed old man emu suspension and my truck drives beautifully even with rear coil spacers and ball joint spacers
        Hi
        I just want to cure saggy arse as going to put a 2" body lift on too
        Daz
          If you carry ANYTHING in the boot, then get the plus 2's as they will cancel out any sag.
          I didn't get +2"'s when I fitted my plus 2's, but what I did get are some superior springs which are a lot more progressive. I've put over 500 kg of bricks in the back before and had less sag than the originals with nothing in it!
          If you are looking at lift, go for the +2"'s
          If you are upping the TB's or fitting BJ spacers get some coil spacers as well.
          And don't forget the dampers - the originals will top out with plus 2's and spacers.
          I think I'll get plus 4's for my truck as I have +2 springs and 2" spacers... Makes it future proof aswell. Just in case!
          www.johnthebuilder.info
            am proper thick me lol,
            so if no weight in boot could i just do standard springs then my 2" body lift ?
            cheers
            daz
              cheers
              daz
              You could....but it begs the question, doesn't it?
              You want lift.
              The time to fit plus 2 springs is same as standard, but gives you lift.
              You could just fit the plus 2's and wind up the TB's instead of doing the body lift...
              Think what you want to achieve in the end, not what's next on the list...
              see my thread for different pics at different stages of lift.
              http://www.hiluxsurf.co.uk/showthrea...t=68310&page=5
                hi wolfracer
                so 2" longer springs . does that meen 2" longer shockers
                too ?. what are tb's and would i have to move rad ?
                cheers
                daz
                  hi wolfracer
                  too ?
                  cheers
                  daz
                  yes, but in reality, your shocks will still have a lot of travel. depends how much articulation you want. Remember road handling will suffer if shocker maxes out.
                  i'm still on standard shocks with plus 2's AND coil spacers. But someone else I know has same set up and they've maxed out.
                    just edited last post mate
                      TB = Torsion Bar = front "spring". I've got the 3.0l, but I think you do have to move the rad on yours, someone else will confirm. But only for Bodylift.
                        thanks for that, just had a scan and if i only go 2" then no need to move rad.
                        so 2" bigger springs and tb's on front 2" ?
                        cheers
                        daz
                          cheers
                          daz
                          TB's won't wind up 2", maybe 1.5" I think, but might be wrong.
                          Have a read around the subject mate. Think you'd make a better (ie more informed) choice if you have ALL the info you need. loads of info on here.
                            ok
                            cheers for help and info its been a great help
                            cheers
                            again daz
                              Is this as bad as they get.....
