How to drain coolant if no drain plug?
  • How to drain coolant if no drain plug?
    Hi, after a very frustrating hour with a torch, I'm pretty sure I have a replacement radiator with no drain plug..unless anyone has any other suggestions. I assume the plug is reasonably obvious even with an a/c radiator in the way..
    So, where to drain the coolant out?
    Thanks...
    the drain plug is/should be on the bottom n/s facing the bulkhead
      Just take the bottom hose off, the coolant will fall out.
        Cheers. I've looked and looked cant find or feel anything that could be a drain - and saw on a search that the roughtrax rads don't have a drain plug?
        Edit - and I guess taking lower pipe off means getting the a/c rad and fans off..
          No, it doesn't.
