Excellent. Why then in your first post did you say you had no engine codes. Would have made diagnosis loads easier. Never mind, good luck and happy surfing.
new engine problems
correct no codes as in my first post, this is what i clued into, when i was recieving a code 11 before the rebuild the tps was sending a code as it was not in the correct position, then after the rebuild the mechanic had the issues they tried adjusting the tps, when adjusting the tps it would remove the code 11 as the tps was no longer in the in the same position, the tps was not sending the required voltage to the ecu but still providing enough resistance to trick the ecu it was still there so no engine light, kinda hard to explain.
