I've noticed a small 10mm-ish hose coming up between the rad and the coolant expansion tank. It's not connected to anything, but it's got a plastic barbed connector on the end as if it should connect to something.
I've gone back over some pics I took while everything was in bits, and I think this is where the other end of it goes...
Splits into two. What is it and where should it go?
Bound to be something obvious!
Dan
Dan
