Clutch
  • Clutch
    How do you bleed it ? I am about to swap the Master cylinder
    Mark
    Mark
    Hi Mark,
    If ya talking about bleeding the Master cylinder
    1. Clamp the M/C in a Vice( if ya got one) not too tight, (take out the bung in the pipe fixing aperture) fill with Brake/Clutch fluid.
    2. Moving the arm actuator push n pull with ya finger lightly over the pipe fixing aperture untill some pressure is felt n fluid is visible.
    3. Fit Master Cylinder n connect the pipe & bleed at Clutch master cylinder .
    Good Luck
    Jess
    "Cos short cuts cost more in the long run"
    Buncefield Burner
      thanks Jess
        Clutches can be a bugger to bleed, sometimes it's easier to pressure/vacuum bleed them.
