hi there was just wondering if anyone had a mini guide on how to replace the old one with a new one as never touched a servo before but willing to give it a go if not to complicated cheers
brake servo replacement
Never done one on a Surf, but a generic process would be:Originally posted by chubby View Posthi there was just wondering if anyone had a mini guide on how to replace the old one with a new one as never touched a servo before but willing to give it a go if not to complicated cheers
Remove the O/S lower dash (assuming RHD)
Disconnect the push rod from the brake pedal
Remove the master cylinder
Remove the old servo
Fit new servo
Re-fit master cylinder
Re-connect brake push rod
Bleed brakes
Wash hands
Re-fit lower dash
Job done.Do you know that, with a 50 character limit, it's
I'd suggest bleeding up the new master cylinder before (Re-fit master cylinder)Originally posted by Albannach View PostNever done one on a Surf, but a generic process would be:
Fit new servo
Bleed brakes
Wash hands
Re-fit lower dash
Job done.
Jess
"Cos short cuts cost more in the long run"Buncefield Burner
I was going on the assumption that the old MC was being used and that he'd block the outlets to stop the fluid leaking, but yes, pre-bleed the MC if it's being replaced.Originally posted by Diezel Weazel View PostI'd suggest bleeding up the new master cylinder before (Re-fit master cylinder)Do you know that, with a 50 character limit, it's
[/U][/B]
