My air con works but not as good as it should be, I had my local guy come round to top it up as you could see the cotton wool effect in the dryer sight glass.
He eptied the system and refilled, the sight glass is now clear, as it should be, but he reckons the expansion valve which is behind the glove box it jammed half shut or has some debris jammed in the valve.
Has anyone ever changed theres and if so where can I get the expansion valve from if I need to buy on?
