universal joint rear prop
  • universal joint rear prop
    how do i change the rear prop universal joint at the rear that gows onto the diff please guys the shaking bad thanks john
    Follow this basic guide, it's the easiest if you haven't got access to a big vise or press, but remember to prise the circlips off each leg of the joint first.
    http://www.youtube.com/watch?v=MugYJbBVpCs
    Dab paint marks on the mating surfaces of the propshaft/flanges (both ends) and mark the sliding joint too so that it all goes back on in exactly the same position.
      The only difference to the video is that the retaining clips are on the inside of the joint, or at least they are on a 3rd gen.
      私のホバークラフト は鰻が一杯です。
        thanks
        thanks guys it was the uj on the rear renewd it at a cost of 20.50 pence got it back on and greased it all up huray no shaking thanks again
