Help Wiring
  • Help Wiring
    Help just fitted new head but s$%THEADS tried to rob her riped the wiring apart from near ignition the ignition wires have eight wires coming from it,the other half as seven 4 are colour coded so i wired them together,there are too wires on the ignition white,but there is no white on the other half,there is also a thinner black wire,so i touched this to the black ones i wired up and everything lit up windows working lights dash ect even turned key not enough jucie in batts but cranked over DOES THIS SOUND LIKE THE WIRING IS OK EVERYTHING TURNS ON AND OFF ECT.As anyone got aNY ADVISE CHEERS STEVE...
    NEVER GIVE UP SHES WORTH IT*
