hi all thanks for the help with changing the glow plugs now im ready to change the fuel filter i can see how to get the old one off but want help with how to put it all back i can see its obvious but i see people go on about bleeding them is it not just a case of filling new one with deisel and fitting it in place please help many thanks
help with fuel filter please
i changed mine the other week, dropped off the 2 hoses, clamped the one going to tank, took out filter, put bracket into vice and used a oil filter socket on it, popped of, no hassle,
then rubbed a bit of oil on seal of new filter and filled with redex, and a drop of white spirits, to fill filter as i had no diesel lying around, tightened up filter put back in and connected 2 hoses, cranked the engine and off it went.....
now to do my long put off body lift :P
Originally posted by BigBobE View Postthen rubbed a bit of oil on seal of new filter and filled with redex, and a drop of white spirits, to fill filter as i had no diesel lying around, tightened up filterDo you know that, with a 50 character limit, it's
Originally posted by BigBobE View Postcaught a good firm grip with 2 handsand twisted,
It doesn't need to be very tight, just 'nipped' up by hand.Do you know that, with a 50 character limit, it's
