fuel filter heater
  • fuel filter heater
    does your fuel filter get warm to the touch or has mine stopped working or is there a fuse for it anywhere i have had a quick look but couldnt find one and does the relay give any trouble any advice would be great
    cheers shaun
    NO LONGER A SURFER NOW DRIVING A LEXUS
    PS
    i was sure mine used to get warm????
    cheers shaun
      Shaun not all the fuel filter housings have the heaters in them and most of them i think pack up after a while anyway so i wouldn't think that would be the cause of your problems.I do have one of those fuelcat veg/fuel heaters here if your interested in it tho if it will help you out
        thanks rich i have disconnected the batteries on thursday and i am going to reconnect on sat weather permitting after speaking to you on wed night i went out thursday morning it started up fine and revved like a good one so i am trying to reset the ecu just in case it has a fault code stored in it always my luck get snow to play in and my truck packs up i will let you know about the heater if this doesnt work .
        cheers shaun
          right on Shaun.Let us know how you get on
