Hi-Low range selctor lever issues...
  • Hi-Low range selctor lever issues...
    Felt like the Hi-Low range selector lever had popped out in my Surf so decided to take things apart to have a little look today. Just above where the ball joint is inside the guide plate it seems there was a nylon washer of some sorts which has disintergrated into nothing. See Pics below. Can somebody confirm this is right and advise where I can get one from or is it one whole part.
    Cheers,
    Yardstick.
    Can't say ive had one apart before but you could try the roughtrax website. They sell most things or stormforce on here sells 2nd hand spare
    www.cnpbetterhomes.co.uk
      Couldn't see one on the site, but guess its a random bit so going to e-mail them next week and send a pic etc to see.
      Anyone else that may have seen this before please feel free to add your comments.
      For the time being I've put it back together in a way that means I can still use it, just quite a lot of play in it right now.
        I have got a knackered gearbox on a 3.0l so i can take the hi/lo selector off of that for you if you want £20 delivered and it will be in the post monday or tuesday
          Are all the plastic/nylon bits on it solid and ok? Pics?
          Thanks,
          Yardstick.
            its all still on the truck.it was all working perfectly ok before i buggared the back of the trans box.i am busy fitting parts for someone tomorrow so i can't get it off till tuesday now
              That's fine mate I can wait!
                Do you want me to take it off for you or do you mean you can wait for a while
                  Sorry. What I meant was take it off when you can, take a pic, post it here. If it all looks good then I will take it.
                  Cheers.
                    I'll get it off tomorrow for you and post up a pic on here
                      Any luck with this yet mate?
                      Cheers.
                        Sorry i will sort it this weekend as the weather got bad here and i have been tied up a bit running nusres about to the hospital and home again.
                        I will sort it tomorrow and post the pic for you
