Ayup, does anyone have the sequence for tightening the head bolts on a 2.4LTE. I'm pulling my head this w/end and would like to remove bolts in correct order (just in case the head ain't cracked).
Head Bolts
Undo them in the reverse order.
Tightening them in sequence is to allow the gasket to compress properly. Slackening them in sequence on a cold (24 hours after running it) engine isn't too important.Do you know that, with a 50 character limit, it's
OK head lifted, not a pretty sight, and I've lifted many over the years from LR's to RR Merlin. Large cracks btween all four sets of valves and massive amount of surface damage on 3 & 4. Pistons are perfect as are bores. Hope the pics tell the storyLast edited by Bazza52; 4 January 2010, 21:29.
