I've had the brake line which goes to the rear split where it goes over the fuel tank. There was a lot of corrosion to the line at this location
This split on the MOT test as the tester pressed the pedal .... to the floor
Anyway, the garage has replaced the line, but now tell me that they can't get any pressure into the system and the brake pedal just goes to the floor. They have bled the system numerous times from various points, but no joy.
They say that the master cylinder may have gone.
Now, there was no brake problem before this line split, so ..... could the master cylinder be faulty, would the line splitting and the pedal being floored have damaged the master cylinder, and if so, can the cylinder be repaired or must it be replaced - £300 ouch
Or is there some particular thing to do or try when refilling the brake circuit
cheers
cheers
