Coolant loss problems
    Originally posted by Bibs View Post
    No leaks - never loses any apart from throwing out the expansion tank when it bubbles over. Then draws it back as it cools.
    New water pump last year and has good pressure round the system.
    Lookin at gettin one now xxx
    Daft question, but there's not any tiny leaks at the top of the rad? Mine had pinhole leak, only found it when engine was warming up as when fully hot coolant was drying before you could see it.
    Also are you checking coolant level in the filler cap every morning?
    My other cars a QUAD
    (sv1000spilot on surf forums)
      Lol - just noticed I put kisses there, forgot where I was for a min
      Anyway - yeah check it every day and its fine. As I said not losin any water any other time.
        sounds exactly like mine
        I removed my thermostat, filled the system from the bottom pipe (I Think) till it went through the engine and out the top of the rad. ran it for a while, with a good few revs to bleed it, topped it up, did it again, replaced thermostat, a few minutes of idling with a few revs, topped up the system. Never had problems again
        私のホバークラフト は鰻が一杯です。
          Facebook mode
            Well fingers crossed you're right.
            Facebook mode
            Yup
            Need some love over here lately anyway
