hi guys , for some reasons on my surf 2.4 td the overdrive light flashes when i m driving, any ideas why????
Overdrive!!!!!!
It indicates gearbox fault. As Matt says, search 'ECU codes'
Which reminds me - must sort out my speedo sensor problem before my MOT next month. I'd miss the OD light if it wasn't flashing now though. kind of become attached to it...Cutting steps in the roof of the world
thancks pjlarambla
would you know where the speedo sensor is located??? do you know if it is an expensive item to replace?
Is your speedo working O.K. it normaly means a speedo senser has gone if your o/d light is flashing when driving, take it that your o/d is connecting when driving or are you just in third.[/QUOTE]
Originally posted by antonello View Postthe speedo is not working and the o.d light is flashing, however the car changes gears ok and if i press the d button the car seem to go down a gear ok! does anyone know the location of the speedo sensor??
There seems to lots of different ideas on this, had the same problem, checked all sensors, finaly I took out the dash and removed the speedo, found slight burning on one of the traks, replaced the speedo as this seemed the cheapest option, all worked great and has been ever since. Have since found out that there is a resistor in the speedo that burns out, which causes the trakes to burn.
You should be able to pick up a really good clustor on this site, for about 25 quid.
Have a go at this first, and its the easyest job to do.Be Lucky
