Airlocks
  • Airlocks
    I'm just in the later stages of a full engine rebuild, and I'm starting to worry about airlocks when I refill the cooling system. One of the most expensive parts of the rebuild was a new head, as the old one had cracked. The car has never heated up (steaming etc) or showed any signs of overheating, so unless its been there since i bought it (4 years, 80,000km ago), I think it can only have happened when the cooling system was drained and refilled when i had the timing belt replaced last December.
    So the last thing I want is an airlock and a big crack in my new head. Any suggestions?
    I was thinking about filling the pipes separately - into the heater matrix, into the ACSD on the injection pump, and directly into the thermostat cover. Would that prevent any airlocks?
    Daniel
    http://eurasiaoverland.com/
    Fill the system slowly and you'll be fine. It's rapid filling which tends to introduce airlocks.
      Turn the heating on to full, including the rear heater.
      After you've run it top it up.
