80amp fuse help
  • 80amp fuse help
    how on earth do i remove the 80amp fuse near drivers side battery for glow plugs?
    looks blew to me, but i cant get it out!
    Russell
    http://www.hiluxsurf.co.uk/forums/sh...glow+plug+fuse
      so, got the fuse out, no point putting another in as it will blow, what could be causing it?
      do i need a new set of glow plugs? is there a special way of removing/fitting them?
      should i be looking out for something?
      cheers in advance
      Russell
        I would think that the insulator on the buzz bar is in the wrong location so the bar blew the fuse as it is earthing out ..........
        Some one has reassembled it incorrectly probably after changing the glowplugs
          the head was changed a month ago so im guessing it could of bee re assembled incorrectly then?
          sorry for being thick but the insulator / buzz bar is on each glow plug right?
          Russell
            Most likley that the buzz bar for the glow plugs has been assembled inccorrectly
            Look at this
            http://www.toyodiy.com/parts/p_J_199...JMGX_1901.html
