just a couple of quick questions
how do you know if the stering damper is knackered is there any specific tests you can do?
steering idler arm just brought some new bushes from roughtrax is there any torque figures for the tighting bolts? (on the arm itself not the mounting bolts) also seen on some later models there is a grease nipple about halfway up the idler tube as mine hasnt got one i might drill and tap one in has anyone else done this and what grease do you use.
