I have a problem with my surf n/s/r window, it will go down but not up, I have changed the switch but still same, I tried changing the master drivers switch and again still the same. Is there a window ECU that maybe at fault? If so where is it or do you have any other help you can give. Regards Dave.
N/S/R window problem Can anyone help please ? ?
