Queer Qindow
  • Queer Qindow
    Hi,
    Here's the situation:
    With the key, the rear window goes up and down fine, just sticks a bit near the top, however from inside the car the switch only works one way, i.e: you can close the window from inside the car but you can't iopen it?
    Sound familiar to anyone?
    Any advice greatfully received
    Duff switch??
    Try swopping the up & down wires on the switch and see if that works .
    My other cars a QUAD
    (sv1000spilot on surf forums)
      i had the same with mine when i picked it up, it was a broken wire at the nsr wiring where it goes into the tailgate, common fault on these.
      have you checked all wires?
      if not then probably faulty switch.
