My truck is parked at my sisters, whilst getting fixed.Went up this morning to strip head of ready for new one.
YES the thiefing f*!*ers tried to have it away
.damaged door handle,barrel,ripped of bottom shroud.But the worst is they have ripped the wiring apart.The above i can replace lucky ive got new handles and barrel shroud will bolt back on.The wiring tried it kick it up but theres wires still left over.Soz i have no pictures.But as any one got photos or anything to help me put them in some sort of order so i can put a blog on them
.Theres 4 wires the same on each end put the others are different.My truck is L reg,2tl-te 2.4 turbo.Thanks for your time.The wiring is from the ignition that went on to clip into another cip but they ripped them apart,if you now wat i mean ignition wiring---clip then loom wiring--at the back of bottom shroud. THANKS
