how can you tell if its an efi engine or not can ne 1 tel me
efi or not
Type properly and you'll get a quicker answer.Originally posted by hilux303 View Posthow can you tell if its an efi engine or not can ne 1 tel me
What year is your truck? One of the turbo pipes running across the rocker cover will have EFI or something similar cast into it.
2LT engines are not EFI, 2LT-E engines are.Do you know that, with a 50 character limit, it's
On my EFI engine, it's on the front of the throttle body opposite where the throttle cable cam is.Originally posted by hilux303 View Postok then i dont know i read the codes on the ecu and it comes up with erro code 4,7 i know what 4 is and it sead 7 was the tps senser but i doont know were to find itDo you know that, with a 50 character limit, it's
