heads off ,no visible cracks
  • heads off ,no visible cracks
    should i take it to be pressure tested .
    i've taken it off because there's oil [lots of] in the water and i can only think its the head or gasket,
    Not sure if it's a pressure test they do for cracks but definatly get it looked at now it's off.
      you could do with having the head tested for cracks there are different methods used for this the one common way is a blue liquid which coats the head & seeks out any cracks after a while you can physically see the cracks
        what if its cracked in side somewhere.
        i dont even know if it is the head so i dont want to buy a new one and then find out it was a seal in the turbo
        the head has been off before if this means anything
        tanks cody
          Its worth getting it checked out anyway. cast heads usualy crack not warp. alloy heads usually warp.
            who mentioned warping
              FYI just in case you were wondering if it was
                never thought of warping
                i assumed it was a cracked head because of all the surfs with this curse
                and nobody has told me it could be anything else
