Diagnostics Socket Location
  • Diagnostics Socket Location
    Model: LN130 2.4 TD (AUTO) RHD
    Ok I've found the diagnostic socket in the engine bay and linked TE1 and E1 - had a stored fault (7) but disconnecting/reconnecting the batteries cleared this.
    The procedure also mentions a diagnostic socket in the passenger compartment "usually located under the driver's side dash board" so that road test diagnostics can also be carried out by connecting TE2 to E1.
    Problem is, where is this passenger compartment socket?
    Cheers,
    Jonathan
    Stop looking, there isn't one. 7 is TPS (Throttle Position Sensor).
      Blast! I'll have to come up with another excuse to lay on my back in the footwell sniffing the brake pedal rubber!
      Cheers,
      Jonathan
