Oil seal part numbers
  • Oil seal part numbers
    Hi all can anyone please confirm these are the correct numbers for a 1993 2.4lte ssr-x ln130
    Front crank seal 11301c
    Front cam seal 11305a
    That's funny. I was just looking up seal part numbers.
    Crank 90311-42026 This is a Viton Seal. An Alternate seal 90311-42012 which was used on earlier models can be used.
    Cam 90311-32020
    Nev
      Thanks Nev !!
      When I rebuilt the engine last year I fitted the seals that came with the aftermarket gasket set which were fine, for about two months then slowly they started to weep oil and now I leave my oily signiture where ever I park ..... not good
        I sell Timing Belt kits and always supply Toyota seals. I did a lot of checking for aftermarket and decided they just weren't as good. Toyota use NOK seals which are the best. These are almost impossible to find through other sources as NOK usually deal direct with the vehicle manufacturers.
        Nev
