Smoke on start-up, rough idle
  • Gaspode
    replied
    mine does exactly the same thing, but i just ignore it. it only started doing it after the injection pump was replaced. when i start i get a lot of grey smoke for about 5-10 seconds, but after that its fine. i think it may either be the ecu temp sender thingy from the pump, or it could just be old age. i just start up ,no revs and its well within 10 seconds.
    So does mine and I've ignored it, my old mans diesel Passat does the same thing, I was under the impression it was part of the joy of diesels!
    When I was a young'un my dad had a transport company, at five am when the lorries were started you couldnt see across the yard for smoke, I thought it was normal!!
    Leave a comment:
  • toyboata
    replied
    on sat I got back from Switzerland, 14hr drive. on the way there it was a bit different. 20mins from the place we were staying at, the trucks temps hit the roof. after getting recovered, getting 2 chalet, being up 48+ hrs we pass out and hope the truck isn't 2 serious. in the morning the AA ring with some good news. Just the thermostat needs replacing. A few hrs later they ring bk saying the radiator needs flushing. the next day we go and pick the truck up from the garage 550 Fr bout £350 I don't care I got my truck back,
    but ever since all these problems my truck wont start cold without cold start and then will sit there with the revs just over 1000 coughing and spitting out white smoke. it seems like its miss firing. I've had this problem before and had the glow plugs replaced but that didn't solve it, this time its worse. my dads mate thinks it could be the fuel pump. any ideas?
    Leave a comment:
  • potif
    replied
    [*]Blocked injectors.
    Does anyone have a source of new injectors? I'm going to find it hard to have the car off the road for a week to have mine reconditioned. I found HIFLO I-NEWTSGR08A-HF but they don't appear to ship international.
    I've just ordered a set of recon injectors from diesel Bob - £33 each plus £80 deposit until old ones have been returned. They haven't arrived yet but I'm hoping to get them in on the weekend.
    Leave a comment:
  • stormforce
    replied
    .i have some 2.4 ecu's here if you need a replacement.£75 next day delivery
    Originally posted by daedalusminos View Post
    OK, I'm still working on the difficult start/rough idle/smoke when starting from cold. After reading previous posts I've got a few theories:-
    1. The ECU is not fuelling correctly for a cold start.
      As far as I know the engine temperature is determined by comparing the reading from the Engine Coolant Temperature sensor and the Intake Air Temperature sensor - if the coolant is hotter by more than (something like) 10C then a hot start is assumed. Both of these sensors are covered under diagnostics codes (4 and 8) for open (and possibly short) circuit but probably not for out of spec resistance.
      I measured the resistance of each sensor and compared the values to typical values published here. The reading were ECT = 4K88 and IAT = 4K41. These seemed reasonable values considering the outside air temp was approx 7C. The ECT is tucked up under the inlet manifold but is not too bad to get to - remove N/S battery, airbox, fuel filter assy., EGR link pipe and EGR vacuum control assy.
      I also measured the harness for opens and shorts - no problem. There's always a chance the ECU is faulty.
    2. Airlocks in the fuel line.
      I also had a theory that fuel was syphoning back into the tank - I know my filter primer was faulty so decided to fit an inline hand primer (which has a one way valve in) between filter and pump, I also fitten new fuel line.
    3. Blocked injectors.
    4. Faulty pump
      Haven't looked at this yet
    5. Something else!
      Still plenty of other things to try!
    Despite trying the above, the problem still exists!
    Jonathan
    Leave a comment:
  • gwh200
    replied
    OK, but I said YOU'RE NOT THAT OLD.
    ok, ok IM not that old.........but all these cars are
    Leave a comment:
  • BUSHWHACKER
    replied
    well it is 18 years old in a few momths.its had a new head,glo plugs...and a pump.just think back to circa 1990 when diesels were very agricultural,you had two methods of cold start assist..glo plugs and the fuel pump starting on full fuel,there was no ecu control. its always possible to get it to start faultlessly,but it has to reach a point when you have chucked enough money at it.i do intend to replace the injectors this year,but im not prepared to do any more.it gets serviced regularly so its ended up how its ended up.i just put up with a rough start, but earlier diesels can do this,the only real solution is to replace everything, but i dont feel its worth it for such a minor inconvenience
    Leave a comment:
  • gwh200
    replied
    You're not THAT old.
    Leave a comment:
  • BUSHWHACKER
    replied
    Leave a comment:
  • gwh200
    replied
    Leave a comment:
  • daedalusminos
    replied
    4. Faulty pump
    5. Something else!
    Jonathan
    Leave a comment:
  • coolsv650
    replied
    Hello Gman
    Did you have smoke/misfire before fixing the sensor or just difficult starting?
    Which ECU temp sensor are you referring to?
    Cheers,
    Jonathan
    The ECU temp sensor is in the block just above the starter motor, and its a complete pain to get to. it tells the ECU what the engine temp is so that it can adjust the fuel accordingly. If it fails completely you would normally get a code 4 warning.
    My 2.4 had the exact same problems and had injectors, glowplugs, bypassed the filter head, removed the EGR valve, moved the crankcase blowby pipe from the inlet tract and never managed to solve the problem. Mine happened the same time, after replacing a cracked head.
    The only thing I had not tried is a compression test on the cylinders. I know my 2.4 had been seriously overheated and I thought that it might have damaged the rings but couldn't get my hands on a diesel compression test kit.
    Leave a comment:
  • GRASSMAN
    replied
    Hello Gman
    Cheers,
    Jonathan
    Hi Jonathan,
    Problem started after I removed the starter motor for repairs, no prob untill then, I think I damaged the sensor/cables refitting it. THEN it would'nt start,
    sometimes over 30 seconds churning away, smoke, rattles and missing but fine all day afterwards. The ecu temp sensor is hidden under the inlet manifold
    screwed into the block above the starter.
    http://i293.photobucket.com/albums/m...nsors002-1.jpg
    http://i293.photobucket.com/albums/m...nsors003-1.jpg
    There should be two wires to this sensor.
    hope this helps
    Gman
    Leave a comment:
  • daedalusminos
    replied
    Hello Gman
    Cheers,
    Jonathan
    Leave a comment:
  • GRASSMAN
    replied
    I've had the same probs after changing the starter contacts a few weeks ago. Tracked it down to the ecu temp sensor, (broken wire/sensor) replaced them today, and it started first twist after standing for three days.
    BTW no smoke no missfire.
    hope this helps
    Gman
    Leave a comment:
  • daedalusminos
    replied
    OK, I tried blanking off the EGR valve with a coke can gasket. That made absolutely no difference to the difficult starting/grey smoke/rough cold idle. I'm not sure whether it's helped with the 'smoke in headlights' feature as roads were full of spray this evening.
    Still looking for a solution.... now looking at fuel starvation caused by an airlock - I know my primer doesn't work properly as when I changed the fuel filter, the only way I could prime was to crank for about 30secs (no pressure on the primer plunger). So I was wondering if when left the fuel could drain back, a bit left in the pump/injectors for a start but then runs rough until more is drawn through??? No apparent leaks though.
    Still looking and not given up!!!!
    Jonathan
    Leave a comment:
