where to plug it?
  • where to plug it?
    Hi, 2.4 auto 1993. Under the engine bay,right on the front diff there is an electric cable loom that splits in the wires with connectors on them: one goes into the front diff which I believe is the add switch,one goes at the back of the diff (round 2 pin plug) and one of them is just hanging there (4 pins plug) and for the life out of me ,can't find a socket to plug it in. I wonder if is anything to do with my 4wd that has problems,or with my oil pressure gauge that doesn't work. Thank you.
    look up around the area of the upper wishbone if it's a round white connector and the cable's long enough to reach that far, especially if you got 4wd problems.
    =SOLD UP!=
      Thanks. Driver side or passanger side?
        passenger side
        =SOLD UP!=
          Sir,your a star. Thank you very much,4x4 working now as it should. Regards
            =SOLD UP!=
