hi all
i'm pretty sure my alternator is on the way out - have had trouble starting once or twice, noticed voltage is lower than it usually is before i start the car, and with engine running voltage sometimes doesn't seem to go up when i rev.
so...
is removing/replacing the alternator an easy job? is it worth getting a haynes manual?
and if i source a secondhand alternator, what are the different types? i've noticed talk in here of the vacuum pump being mounted in different positions for different alternators for the same engine type - or am i getting that wrong? my surf's a 1990 2.4LT manual import, LN130 i think?
any help much appreciated!!
so...
