if i put in a manual rad what is a good cheap if their is such a thing oil cooler for my truck????
oil coolers
Somebody put a Range rover v8 one on the front, roughly where the crossmember is.Originally posted by pirate-storm View Postif i put in a manual rad what is a good cheap if their is such a thing oil cooler for my truck????
What about 2 MGB/Mini ones, would that work??
Bring me the head of a treehugger
tyr this
http://www.hiluxsurf.co.uk/forums/sh...ght=atf+cooler
I'm running the same set-up as this. But if you're fitting a manual radiator, then you can bypass the bit about running through the bottom of the auto rad, and use the cooler seperately.Hold my beer and watch this
