whay is it my ariel goes up after ignition off
  • whay is it my ariel goes up after ignition off
    turn ign off and my ariel goes up then back down again... why why why.
    hi mate im trying to wire my sterio at mo and have found that the ariel has two wires to it it might be the wires need to be swapped around if you look on the site there is a wireing guide for are wagons hope this helps
      will have a look see
        Is the CD player in and on?!
        It might just be sending out a strange signal.
          headunit is off.
            Mine has always done that. Some times it sticks.
              Mine does that as well. On mine its the interior light comming on that makes it go up. Switch off engine 'Ariel down' ,open door to get out 'Ariel up' ,shut door and lock 'Ariel down'. You have to switch off and get out and shut door before the ariel gets fully down. What fun
