Fuel pump leak, seal help?
  • Fuel pump leak, seal help?
    ok as a few people know i have done this allready, i used the roughtrax kit which didnt have the seal 4 the TCV i think it is (round one at the bottom under the 4 out lines)
    i have heard about viton seals? what are they and which ones and where do they go?
    does anyone know of any better kits.
    before you say anything i Have to fix it myself cos i cannot afford any other way,
    i am lucky to still have my old pump so i can use that
    Its all fun and games till someone looses an eye!
    try the main dealers
      If ya having trouble obtaining any seals / Kits Try these...
      BENNETTS DIESEL DIAGNOSTICS
      3, Regal Way,
      Watford,
      Herts.
      WD24 4FN Tel. 01923 238523
      Good Luck
      Jess
      There's always a Payback .... Ya just never ever see it Comin !!!!
      Buncefield Burner
        You can get the correct original Denso seal kit from diesel specialists,
        Part No 096010-0630 cost's around £50. This is for the 2.4 efi.
        IT's not how you get in it . IT's how you get out.
          anyone know about Viton?
          and arnt the origional seals a bit keck!?
            Any seals produced and sold these days should be made from viton, or similar, including the aftermarket ones.
              yea but would that include the bosch kit that roughtrax sells
                Which part of my sentence above was confusing for you?
                  makes no difference as the Bosch kit does not have the seal i need for the TCV under the pump.
