Injector Pump Seals
  • Injector Pump Seals
    Just a quick question, if i replace the rear bottom seal (one closest to firewall) do i need to get the pump rebuilt/calibrated? Any help would be greatly appreciated. Thanks in advance.
    To do that one you need to take the pump out ......You might as well get it rebuilt at the same time with viton seals (then you could run veg oil if you wished) .
    I found the top one went first the the side ones ........then the large rear one and that is a calibration job , so in the long run rebuild might be best now so you only take the pump out once
