Oil Change!
  • Oil Change!
    How much oil do you need to do an oil change?av been told about 6 to 8 ltrs???anybody confirm!
    Big Elz !!!
    what grade of oil?
    what grade of oil do i need to use on the 2.4ltr surf.
    Big Elz !!!
      sounds about right depending on engine, the max line on dipstick is usually a good indication.
        Around 6.5 Ltrs. Drain the oil, change filter. Pour 6 Ltrs in and run engine for a few minutes allow to settle and check level via dipstick and add if necessary.
