5 Weeks ago, my 2.4 ssrx overheated, culprit was a bust pipe, resulting in a cracked head, firstly the old head came off, defo the head, cracked in 2 places and gasket in tact, so I went ahead and ordered a new head, new cam etc... transferred injectors, new gasket set, while we were in there we got a new oil return from the turbo, new timing belt, water pump, belt tensionner, glow plugs and last week she was reasembled, water tight cooling system, but they had trouble starting her, oh dear. Once started, she runs like a dream, really quiet and smooth, very hapy mechanic. Only issue was that she takes a while to get started and this is where we are scratching our heads, fuel pump primer is sticking according to the mechanic, does not seem to work, so much so that they had to use a vacuum hose to get fuel up to the engine, so here we are 5 weeks later, car has been put back together, I've nearly paid the credit card buill off and I've still got no truck, what could be wrong?
It's only cold starts that are a problem
We've tested the plugs, they are good quality dnso items and we have tested them and all glow nicely off a 12 volt battery.
She had a fuel filter about 2000 miles ago
Runs on biodiesel but I don't think that's the issue as there's only derv in the tank at the moment
The hand primer isn't priming for some reason, is there any obvious reason for this, do they pack/stiffen up?
There has always been a pressure issue with the system (hissing when you take the filler cap off to put fuel in, could this be affecting?)
Any words of wisdom would be extremely gratefully received
Andy C
Surf-less :-(
Andy C
Surf-less :-(
