hi guys hoping you can help
my dad has just wired in a towbar and 30 amp feed from battery (via relay) for 12v in the rear
my problem is since the truck wont go above 2nd gear and im having to drive around either very slow or at stupid revs
im assuming theres a bad earth as the turbo light now filckers when engine running as does the cigerette lighter adaptor i have didnt before
things i have done to try and rectify
1. removed all towbar electrics
2. remved 12v feed to rear
3. checked and dwd40'd all connections i could find
4. when checking under hood there where two pipes that came from under the turbo area that where full of sh** replaced
5. replaced "relay" box under trim that house the gear levers
6. swapped ecu (working) from other truck still the same
still the same please help
i have a l reg ssrg and a l reg ssrx as donor will the main ecu in the passenger footwell be compatible ?
cheers jon
cheers jon
