My 2.4 Surf has a small water leak somewhere on the front of the engine. I can't see anything, bottom radiator hose perhaps?
Water leak
Any chance of a pic of where the leak is coming from, or maybe a more detailed description? We don't have a lot to go on at the moment.Originally posted by ColinF View PostMy 2.4 Surf has a small water leak somewhere on the front of the engine. I can't see anything, bottom radiator hose perhaps?
Paul </Slugsie>
Immortal.so far!
Hi there Colin,
Just a thought , I have had two pipes , bottom hose and a front
pipe that feeds the heater leak.
they must have been the original pipes and over time and use
they have become pourus and was leaking through the pipe
it's self, bit tricky to track down .
Try to ramp it or use a high kerb to have a good look when
it is running to try to locate where it be comming from ?
Check the ovious first rad top/bottom water pump housing etc.
Chris
GOT NO COWBOYS HERE?
