rear drum help
  • rear drum help
    how does it come away? i need to replace a wheel stud for mot tomorrow and have nmo manual + never worked on a 4x4 before are there any guides?
    you need 2 m8 size bolts i think they are to screw into the hubs to pull them off
      Use a DRIFT & a heavy hammer to knock the old one out, You can get the new one in if you spin the driveshaft round but theres no room to hammer it in. Put your finger on the back of the stud & put wheelnut on it to draw it in, You may need to wedge the back of the stud with a Screwdriver or a Spanner.
      Put wheel back on to draw it in fully. JOBS DONE!
        You may ned to back off the adjuster via the hole in backing plate to allow the drum to clear the shoes. As the drums wear they can develop a lip on inner edge that will catch on the shoes.If you force it off you will do damage to shoes and other components.
        Nev
          It's easier with the handbrake off
          =SOLD UP!=
            All done! without to many dramas
              Is that from experiance
              www.cnpbetterhomes.co.uk
                : Not Saying
                =SOLD UP!=
