hi there.
i have just got my surf back from garage and the turbo still does not work properly. they only charged me £40 for 5 1/2 hours work.
when i got home i realized two of the pipes were the wrong way around. after swamping them over the engine has to be revved up to red line for the green light to come on, then when you back off it goes out, it kicked out lots of gray smoke. i went for a drive and when i was powering up the revs in 1st the turbo worked, then i changed into 2nd and all the power went, engine almost cutting out.
i know have diagnostics 4, 7 and 10
also can anybody have a look a there turbo assy censor, i want to know what colour wires go to each number 1,2,3 on the back underside of the censer casing (the bit the censer clicks into).
thanks will
thanks will
