The Engine Check Light
  • The Engine Check Light
    Howdy all, It's the Zimbo again. Just a quick one , does any one know what what the check light on the dash is ment to warn about - apart from the obvious what is the mechanics behind it ?
    Having a scotch and waiting for your replies
    Cheers !!!!
    IF you short two of the terminals in the Diagnostics box (usually next to the fuse box under the bonnet, then turn the ignition on, the amount of flashes on the check light relates to different faults.
    Easy,
    Wheres my scotch?
      this may help
        Easy,
        Wheres my scotch?
        Bit difficult to pass you a scotch, so I had one for you! , Do you have any idea where I can find the codes for the flashes ?
        Cheers and good health
        Regards
        Justin
          Regards
          Justin
          what these i think there for the 2.4
          Here are the codes for a 2LTE diesel.
          1 - Normal
          2 - Turbo boost pressure sensor
          4 - Coolant temperature sensor
          5 - Correction resistance (Pump)
          6 - Pump speed sensor (Pump)
          7 - Throttle position sensor
          8 - Intake air temperature sensor
          9 - Vehicle speed sensor
          10 - Starter switch
          11 - Switch sign (Vehicle not in P or N or A/C on)
          12 - Timer control valve (Pump)
          13 - Crank position sensor
