Leak Off Rail
  • Leak Off Rail
    hi all sorted the injectors they split in 2 and what ever it was in the middle was crushed so i got some brass washers filed them down but them in the middle then filed the washer the same as the nut if you do this your self watch out 4 the spring and a very small nozzle that goes on top when you seperate them anyway that job done the only thing is i put them back in fitted the rail and at no1 injector it snapped i turned it over injectors holding great in the middle now i need a leak off rail anyone got a spare i can buy cheers wont b on 2 long on computer so il pick up info in next couple off days.
    NEVER GIVE UP SHES WORTH IT*
    i got one here for a 2.4.£25 delivered
      rich e-mail me ur no ill give u a ring [email protected]
        email sent Steve
          RICH not received it yet give me a ring on this no and ill ring you back 0161 703 7407 if u dont mind that is.
