hi everyone just got back from work noticed puddle under car its deisel looks like its coming from 2,3 injectors any one got any for sale if so how much how many mi truck is 2.4 tdi tl-te 93 plate cheers
Hi Stevo have you checked how tight the nuts are on the leak off pipe before buying injector's. I may be able to help you with a set but will only know tmorrow if ive still got them
IT's not how you get in it . IT's how you get out.
if the leak off rail is loose,dont tighten the nuts without holding on to the rail or else it will snap,and cost you £20 from a toy stealer.
