Power steering problem
  • Power steering problem
    Folks,
    I started having problems with my power steering over the weekend. I drove 5 miles to the shop on sat night, no problems, parked it up for 30 mins and when i came back the steering was heavy as hell.
    Now when i start to turn the wheel the wheel starts to vibrate like its trying to do something, I have checked the fluid level and it seems fine.
    Have anyone had this problem before, is it more likely to be the steering box or power steering pump
    George
    Is the belt tight?
      i'll check it, its it the main belt or a secondary one
        It's just the one belt, right hand side as you look at the engine.
          Make sure the pump has not broken a mounting or adjuster bolt. This can happen.
            cheers guys - i'll check those tonight when i get home and report back tomorrow
            George
              guys - i was cheeky and popped home for lunch and i checked that pump
              the pump is loose so that explains the problem, now i just need to figure out what caused the pump to come loose.
              I looks like one of the tensioning bolts is missing and from what i have read here, there is a good change that it has sheared off, are these easy to get out, i'll put her over a pit tomorrow night and see what caused it to come loose.
              again guys, thanks for your help so far.
              I must subscribe, i only have the jeep a few weeks and you guys have already helped me out with 1 or 2 problems.
              George
                Jeep? Jeep??
                Subscribe just to be nice. Go on, it's great. It's like sniffing glue without the paper bag.
                  Originally posted by Sancho View Post
                  Jeep? Jeep??
                  sorry - are ye sensitive to that, 4x4 or surf then - figure of speech more than anything!!
                  and i did subscribe - its not huge money and it a good source of info
                    Good man.
                    Thanks from all of us.
                      There are three bolts. A long bolt that the pump pivots on. A bolt through the adjuster bracket to the mount itself I think and a bolt through the bracket into the pump. I think it will be either of the adjuster bolts that has broken rather than the long pivot bolt.
                        definitely one of the adjuster bolts is missing or more than likely broken but I'll take a proper look tomorrow night
                          Here's a diagram with the bolts arrowed.
                            i had a good look last night
                            the adjuster bolt has sheared off, hopefully I'll get it out tonight and repaired
                            I'll keep ye posted
