I recently started a long journey when my temperature shot up and white smoke began streaming out of my exhaust and steam was pouring out of the expansion tank overflow pipe.
I found no evidence of water contamination in the rocker box and no sign of oil in the cooling system.
I am now stripping down the engine to examine the cylinder head and gasket as I,m assuming this is the most likely cause, however I have found oily residue in the Pipe from the turbo to injectors.
I have two questions:
Firstly does anyone have advice as to the best and cheapest place to buy cylinder head gaskets or reconditioned head, if needed.
Secondly is there a gasket/seal inside the turbo that can cause oil to leak and if so can it be replaced and where can I get one from.
pb51
pb51
