Clutch Master and Slave Part Numbers
  • Clutch Master and Slave Part Numbers
    Does anyone know the Toyota part nymbers for the master and slave clutch cylinders. Its for a 1992 LN130 Surf.
    Thanks
    Simon
    Thanks
    Simon
    I think that JimL changed his not so long ago so he should know.
      Thanks
      Simon
      tyr
      try milners Clutch Kit 8/1991 - 7/1997 000107 89.50
      www.milneroffroad.com
        Thanks
        Simon
        master cylinder is £55, slave cylinder is £10 from milners
        [size=5][/size]
          Yeh that sound right Ian, I got them for those prices from Milners. Markys clutch kit part no. sounds like they're talkin bout a 3 piece, not sure.
          The master cylinder was Aisin (as was the old) I'm fairly sure and the slave was Toys R Us probably but it did the trick.... although I feel a bleed job coming soon things getting bit tighter again.
