put pump back in everything lined up on timming checked 4 lose wires ect done everything i know she still wont start noticed when turning over and cracked injectors alittle diesiel coming through and yes primed it through pump ect i really need help.
shes not dead surley
Is the battery/ies fully charged? If you've been trying to start it a number of times today, they would have lost a bit of cranking power. A diesel engine, particularly the older diesels after an overhaul need to spin over quickly to generate enough heat to get them to fire up.
If you're confident that everything is connected up correctly, and diesel is reaching the injectors, then I would suspect a lack of cranking speed due to the discharged batteries is whats preventing if from starting.
Why not take it over to Stevo in Stockport if you're really stuck?
http://www.hiluxsurf.co.uk/members_p...evo/index.html
