well guys its nearly d-day toyota have told me my gasket for the timing belt casing has arrived. does anyone know if when fitting it i need to use a gasket cement aswell or will the gasket do the job on its own.....i'm hoping to remove the sump tomorrow and i need to know if its better to unbolt the front diff crossmember before undoing driveshafts or vice-versa...cheers.
gasket cement or not?
