how many teeth
  • how many teeth
    would anyone know how many teeth are on a 3.0 litre front diff crown wheel,and how many on the pinion ??
    the axle code is g298
    Non intercooled nothing.
    298?
    Must end in a 4 or 5.
    29 is a 4:10, 41 teeth on the ring.
      298?
      my mistake tony its 294(this is for fordy btw)
      does this then still have 41 teeth on the ring ??
        Yeah, it dosn't matter, the last number just tells you the pinion type. 2 = 2 pinion, 4 = 4 pinion and 5 = 4 pinion with LSD.
        The fronts are smaller dia ring, (7 1/2") vs 8" on the rear, but I checked a pair of the 4.8's I have here, they both have the same number of teeth on the ring gear even though the front is smaller so I don't think it matters.
          cheers tony much appreciated
            Isn't a 4.1 ratio 37 X 9 Ring and Pinion?
            Nev
              Oops! Tony may be correct. 37/9 seems to be the older ratio and actually 4.11.
              Just out of curiousity wouldn's a 37/9 be a stronger ring and pinion combination?
              http://www.4crawler.com/4x4/4R_TechInfo.shtml
              Nev
